メインコンテンツにスキップ
Sony Xperia Z3 発売日:2014年9月(グローバルモデル) 日本国内取り扱いキャリア docomo(SO-01G)・・・2014年10月23日発売 au(SOL26)・・・2014年10月23日発売 Softbank(401SO)・・・2014年11月21日発売
20回答 すべてを表示
Flash and Front/Back Camera not working
I have a Sony Xperia Z3 here and after a screen replacement the front and back camera no longer work as well as the flash. When I plug the rear camera in the phone overheats a lot! Any ideas on how to fix this would be appreciated! Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
7 件のコメント
Any updates?? Currently have this issue and can't seem to work out why it is happening. Going to try a new screen on the phone just to retrace every step but if anyone knows anything that'd be pretty helpful.
さんによる
Any fix i having this problem right now help please :/
さんによる
Same problem. help please
さんによる
Did you find the solution to the problem? As much as I've understood, it has to be the flash. Before I broke my phone, I sometimes had flashlight working in some other app and then when I tried to start the camera app the error appeared "Unfortunately camera has stopped".
Did you do something to fix the problem, or had to replace the motherboard?
さんによる
Hey, I've the same problem. I don't know how can I fix it, but a friend told me that he has resolved it just by changing the rear camera. I still doubt but I'll try. I can't see any link between the camera and the flash light.
Is there anyone else has tried to repair it himself?
さんによる
2件以上のコメントを表示
コメントを追加
4件の回答
最も参考になった回答
I'm having A- Z same problem .. After replacing my z3 screen , back camera front camera and flash not working anymore.. Also flashlight toggle disappeared from home screen .. I think problem is related to flashlight . When I connect my back camera the phone heats up and battery drains by 1 % every 2 minutes ..But when back camera is removed battery drains by 1 % every 2 hours ..
I tried every thing from factory reset , repairing through sony pc companion , tried other camera apps , changed camera sensor etc .. I came into point there is some short near camera or problem is due to flash (As flash light is also not working and flash toggle has disappeard from home screen .
Also please note on diagonistic front camera shows up but back camera doesnot shows up .. In camera app when clicked I get a message " Unfortunated camera has stopped " .
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
You could fix?
さんによる
コメントを追加
I send the mobile to repair shop and he solved this problem by change the camera ic
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
How much it cost??
さんによる
is there a way to fix that camera ic by myself? On iphone 6 to fix camera problems just need to make jumper on ic.
さんによる
Bro explain how to fix it??
さんによる
As i understand then these smd resistors we need to repair. Am i right?
https://i.imgsafe.org/7c7544f09b.jpg
さんによる
コメントを追加
Try another front and back camera. Not sure how you're having this overheating issue as I've replaced around 10 Sony Xperia Z3 screens.
Did you put in the plastic mounting bracket for the Back camera? Including the metal mounting bracket which is held by the housing frame of the phone?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This may be a camera application cache problem.
Clear the Camera cache in the settings>Application>camera. Then Clear the whole Application Cache in Settings>Storage and memory>internal memory>(swipe down to) Clear the shared application memory (or smthg like that).
If clear the camera cache cannot solve the problem, you can try reconnect the camera flex cable, cause the flex cable maybe loosen when accidentally drop or hit.
This Sony Xperia Z3 Teardown can help you disassemble it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
William さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 22
今までの合計 8,188
