メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
touch screen dead after water damage, how could I fix it?
I have a iphone 6 and it fell into water by accident. It stayed in the water for 2-3mins before I realized and picked it up. It already shut off. I opened the case after one hour, not much water inside. I let it dry naturally for 3 days before I tried reopening the phone. The phone started, and went to the lock screen. Both the home button and power button worked, but the touch screen dead. Also, the phone seemed to be hotter than before on the back when it was being charged.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
I have on several occasions been able to bring a board back from liquid damage, but never an LCD or digitizer. If that is not working after liquid, you're going to need to replace the screen. I'd also recommend taking the board, battery, and charge port out of the enclosure and inspecting it for any corrosion or residue. Something is there causing the heat and once any corrosion eats through the leads or traces, the board is pretty much gone unless you or someone you know is very skilled at micro-soldering (Very expensive to repair, usually not worth it for most people and its hard to find someone who really knows what they're doing.)
I hope that helps.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Yu Pan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 209
