メインコンテンツにスキップ
1.8 GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.8 GHz)3MB L3キャッシュ
363回答 すべてを表示
Will a battery replacement fix my MacBook Air
I have a MacBook Air with liquid spilled through the keyboard. The system seems to run fine as long as it's plugged in. The system is unresponsive on battery power alone and the battery reports "Needs Replacement" and shows a constant 15% charge.
A hardware test shows a failure of "4BAT/1/40000000 0x898f3790"
Will a new battery fix this problem? Or does it need a new logic board?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント:
Hi
I would like to hear to what solution you have got.
Got a similar Problem. Waterdamage is about 2years ago. Mac only running with power supply. Its lagging like !&&*. The SSD passed the test and i got the same Hardware Error like yours. Would like to know what you have done to get it to work
さんによる
コメントを追加
1 件の回答
What kind of liquid was spilled? Unplug and power off the machine, the longer it is running, the higher chance of a short circuit and more damage. Use this guide to disassemble your machine. Using 90%+ isopropyl alcohol, you are going to wipe down all of the major components and connectors. Immerse the logic board in the alcohol for about 3 hours. Then, take all of the parts and set them in front of a fan to dry. Leave them for 24 hours, or longer if the need more time to dry. Then, once you are sure that they are all thoroughly dry, reassemble the laptop. Try to turn it on with the battery only, then with the power cord only (disconnect the battery). Once you reach this point we can troubleshoot further. Best of luck!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It was a diet coke and my dad spilled it about 6 months ago. We thought the machine was dead until we plugged it in a couple of days ago. We'll try your suggestions and report back. Thanks!
さんによる
コメントを追加
回答を追加する
steven さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,534
