メインコンテンツにスキップ
PlayStation 3 (PS3)はソニーコンピューターエンターテイメントによって製造された3世代目の家庭用据え置き機で、PlayStation 2の次世代機となります。これらは2006年11月11日に発売されました。
781回答 すべてを表示
How can I fix the power button and eject button?
my 40 gyg. ps3 won't turn on when i press the power or eject button. there is no blinking red light it just stays constant red. about a year ago someone spilled koolaid on the buttons but the ps3 still worked after it was dried out. any help would be much appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 10
2 件のコメント
I noticed you never got an answer to this. Are you still having this problem?
さんによる
If something sticky thutches it soak it up then put damp whatter on it
さんによる
コメントを追加
3件の回答
ベストアンサー
Probably the sensors on the control board are not making contact with the buttons. I have fixed this before on a few PS3s. Follow this guide: PlayStation 3 コントロールボードの交換
On the very last step (step 9) you can see the sensors on the left and right of the control board they look like thin metal buttons.
  • Once you have the cover off and the control board exposed, plug in your PS3 and attempt to turn on the ps3 slightly touching the right sensor with your finger.
  • DO NOT PUSH DOWN HARD ON IT!!! all it takes is a slight touch.
  • If the control board is working then the PS3 should turn on. If it does not then you can inspect the ribbon cable to make sure it is connected properly. If it still does not work then your control board is probably dead.
  • Once you have determined that the control board is working then use a pocket knife or a credit card or something thin to pull up the thin metal sensors so that they make contact with the buttons. BE CAREFULL NOT TO PULL TO HARD OR THEY WILL BREAK OFF.
  • Put the cover back on and make sure it now turns on using the buttons DO THIS BEFORE YOU PUT THE SCREWS BACK ON.
I have done this a few times and it has worked every time. If your LED lights still come on then your control board is probably ok and just needs to pull the sensors up just a bit. It takes about 15 to 30 minutes to do this.
I hope this helps, good luck!!
このアンサーは役に立ちましたか?
スコア 9
9 件のコメント:
thanks XnriquX you saved my ps3 :)))
さんによる
No problem I am glad I was able to help out!! :D
さんによる
What if you dont have that model... I have one that does not have a control board (Power Eject Board) its built in to the motherboard what do I do?
さんによる
Can you specify which ps3? As far as I am concerned every ps3 I have looked at has some type of control panel and they are all very similar. Just pay attention to whatever is directly underneath the power and eject buttons and locate the sensors and just pull them up just a bit.
さんによる
Worked perfect! It just saved me $50. Thanks a lot!
さんによる
4件以上のコメントを表示
コメントを追加
If you find rust on the inside of the button's side, take a bit of aluminum foil and scotch tape to resecure a good connection between the aluminum plates and the two prongs. Foil is only needed on the plate side.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Tydith has the same problem as I do, the control board is different (the prongs for power and eject are there but it feeds to the mother board or underneath the metal chassis somewhere). It's a 80gb CECHL01.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
infinitemayhem さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 36
過去 30 日: 164
今までの合計 89,669
