メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
Error: 4SNS/1/40000000: ICOR - 21.925
Hi!
When I run the Apple Hardware Test on Macbook Pro 13" 2.5 GHz 2012.
It shows me error 4SNS/1/40000000: ICOR - 21.925.
Could you explain me what wrong with my mac?
Thanks for your answer.
I understand that my logic board has problem with system sensor.
But, when I try to run AHT test again it shows me the same error but the last number is different all time.
What is this number and why is this number different each time?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Here's a good reference: How to invoke and interpret the Apple hardware tests. I had to use my ASD lookup to get ICOR error.
So if we take your error: 4SNS/1/40000000: ICOR - 21.925 and break it down this is what we have:
4SNS System sensor
ICOR CPU 1.05 V Rail Average Current - Mac Mini (Early 2009)
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Yes, the last digit will likely be different each time you run AHT. Its the current value. really not important here. The I in the error message is current.
さんによる
It's time for a new logic board
さんによる
コメントを追加
The "21.925" number at the end will change each time because that is the temperature it recorded during the diagnostics test.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
If this was a temp error then the value is the temp. Here it's a Voltage rail issue (ICOR) so the value is voltage.
さんによる
You're right and I apologize for not seeing your initial answer to OP.
While I have you, I have a similar error:
4SNS/1/40000000: TAOP-42.398
I've found that this is a bad ambient air sensor. My fans are spinning constantly, even at idle. The computer is fairly cool at touch. Would removing the ambient air sensor resolve this? Or does it need to actually be replaced?
さんによる
コメントを追加
回答を追加する
greytl さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,821
