メインコンテンツにスキップ
iPhoneを自分で修理するために必要なものはすべて揃っています!最新のiPhone 15から、2007年に発売された初代iPhone 2Gまで、iFixitにはすべてのiPhoneに対応する無料の修理ガイドと分解情報があります。
36476回答 すべてを表示
Soldering U2 (what tools needed?)
Hello everyone,
I would like to start micro soldering, i have phone compagny but sometime we broke some chip during repair.
What is all tool needed for remove U2 chip and replace with new one ( i already have the new U2)
Can someone explain me how to desoldering and how to soldering back, which method is the best ?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Hey,
You'll need to start off by getting a good soldering iron, something along the lines of a Hakko, then you will need decent flux, and decent solder at different widths, for smaller stuff go with the thinner soldering wire, try and make sure it's multicore solder as that also contains flux in the solder and helps a lot. A good reflow station will be needed for sure. You will definitely need a decent microscope to, you can't do it by eye, as the chips are so tiny! If you do plan on soldering a lot, you'll more than likely need a fume extractor, as the fumes from soldering are bad for health.
Hope this has helped. :)
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Tools only:
Hotairstation/Reworkstation
Soldering Iron
Solder
Flux
fine quality tweezers (also important)
Changing the u2 chip is one of the easier IC's to change but still not the place to learn micro soldering.
Practise and get to know your tools on dead boards until you know how to remove parts without destroying the whole board.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
PPD120E or good soldering iron
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Phonetech93 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 2,067
