メインコンテンツにスキップ
Released by Nokia in May 2009, the Nokia 6303 is designed mainly for voice calls, texting, and music playback.
20回答 すべてを表示
How do I reset the security code for a Nokia 6303?
Hi, I changed the security code of my Nokia 6303, but I was really tired so I forgot it.
I'm not trying to unlock the pin or simlock code, but the code you can set to unlock the keyboard. I have a USB-cable and I've connected the phone to my Mac via Bluetooth. If needed, I also have a windows computer available, but the phone hasn't been connected to it yet, neither with bluetooth nor the USB.
Please help me out! Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 26
3 件のコメント
I cannot hear any incoming and outgoing call sound
さんによる
i have nokia 6303c and i forgat security code so howe i opn this code plz rply me thank u
さんによる
Works on nokia6303. It’ll read security code from memory
Download & install Nemesis Service suite (NSS). Do not install it on C: drive. It has permission issues on C. I’ll go with D.
Connect your phone to computer using Ovi Suite or PC Suite mode. Close Ovi/PC suite if launched automatically. We don’t need it.
Open Nemesis Service suite (NSS)
Click on scan for new devices button (top right hand side)
And click on phone info button
Click on Scan
Select Permanent Memory
Click on Read
Now it’ll read your phone’s permanent memory and save it on your computer. Browse Nemesis Service suite (NSS) installation directory & go to D:NSSBackuppm. In that folder you’ll see a file named {YourPhone’sIMEI}.pm. Right click on it & open with notepad. Now search [308] within that file. On the 5th record (5=) under [308] tag you’ll see your password like this 5=31323334350000000000. Remove all 3’s & 0’s from that line like I highlighted above to get your security code. Which becomes 12345.
さんによる
コメントを追加
8件の回答
ベストアンサー
http://tipsfromgeek.com/2009/11/how-to-r...
please check this site. It will help you.
このアンサーは役に立ちましたか?
スコア 11
10 件のコメント:
Hi, I haven't got the phone with me right now, since it is my brother's,
but it seems like a good solution and I will try it asap.
I will let you know wether it worked or not.
Thanks
さんによる
The hint from darril worked! Thanks a lot you guys!
さんによる
you should accept his answer ;-)
さんによる
Iforgot my code
さんによる
whether it is a network lock code or keypad lock?
さんによる
5件以上のコメントを表示
コメントを追加
12345
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
sorry - that is a very problematic topic
tho only thing i can tell you is: use google, use it good and you can find it - it took me less than a minute to find what you searching for
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
If you are talking about the mastercode-thing, that doesn't work for my nokia... What did you find?
さんによる
did you try this one: *#7328748263373738# ?
さんによる
the problem is, it's blocked, so I can't type it in...
さんによる
you are trying this with the sim in the phone - right? remove the sim! - but nokia phones normally accept those phone inputs even if they are blocked
さんによる
Nope, no sim in the phone. I can't type anything except my code, when I try *#7328748263373738#, the star doesn't appear and when I type in the square, he tells me it's a wrong code, before I'm able to type the rest...
さんによる
2件以上のコメントを表示
コメントを追加
Hi muthu ,
I will help you.What's your mobile model no?
If you forgot your security code,you can reset your security lock using master reset code.It's one of the best way.If you need master reset code visit
http://www.unlock-free.com/ Here they will need your mobile model no,imei.After that they will generate your reset code instantly at free of cost.So you can easily remove you security lock within a minute.They have reset code for some Nokia and Alcatel mobile models only.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
i forgate my passowsd. ple ans
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
@khan, you are posting a question as an answer to a 3 year old question. It might help if you ask your own question. Use this link http://www.ifixit.com/Answers/Ask/Nokia+... to ask your own question for some help. What have you tried thus far? did you try what the accepted answer suggested?
さんによる
コメントを追加
hello i have forgot security code and please help me!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
just remove your sim and after that turn on the phone and enter the previous code or default code . it's work .
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It was already tried, check Matthias Lemmens responds to markus weiher. It did not work. What worked for Matthias Lemmens was the link from Darril....nice answer, good thought, but does not work ;-)
さんによる
コメントを追加
Ajutați mă sa diblociez sim la nokia6303 emei351505044651571
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Matthias Lemmens さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 73
今までの合計 106,184
