Can I fix my cracked screen myself?
I have a Nexus 6. I dropped it. Shattered my screen. Where would I find the instructions and what tools to use?
It seems like this instruction is for the entire display. Is there any way to replace just the glass?
このアンサーは役に立ちましたか?
It is very difficult to change just the broken glass, but you can get it done here for a good deal: http://www.ebay.com/itm/Nexus-6-Motorola...
Please see the following guide on replacing the display assembly for the Nexus 6: Nexus 6 ディスプレイアセンブリの交換.
このアンサーは役に立ちましたか?
I wouldn't advise replacing the glass yourself. It appears to be a complex process as the glass is glued to the LCD display. If the LCD isn't cracked, it is worth a try. The alternative is to replace the LCD digitizer entirely. Currently the LCD digitizer cost approx 180 USD and fairly easy to install, providing you follow the guides and have the right tools. I would advise you to replace the LCD digitizer, buy a glass screen protector (the replacement digitizers from China are not Corning Glass) and a new case to better protect your phone.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 6
今までの合計 9,045
1件のコメント
Vince N. さんによる
