How to fix my power button?
My power button is not turning my phone off, it is only locking the phone. How can I fix this problem asap?
Hello jacquettasurles,
According to your sounds it could be power switch also software related fault, if power switch not works properly this kind cases comes.
[http://Here |ZTE Boost MAX N9520 Display Assembly Replacement] is teardown guide and you can replace the power key (Step 4)
このアンサーは役に立ちましたか?
Can somebody help me I need to know how to cut on and off my ZTE phone but it takes to long to cut on and off I tried reset my phone but that didn't work ethier
このアンサーは役に立ちましたか?
My volume. Button is not working like when you try to turn the volume down and my power button won't turn off
I need help please
このアンサーは役に立ちましたか?
My power button well not lock my phone or turn it off what do I do?????? And it's bran new I just bought it a week ago and I have never dropped it or anything it's a ZTE MAX somebody please help..
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 7,307
i have this same issue except before my phone died it wasn't locking the screen either.
jmagee166 さんによる
I tried to put my phone into a virtual reality headset and my power button was pushed all the way due to my device being to large for the headset. I am trying to find out how do i manually fix my problem.
GucciRu さんによる
I can't get my ZTE MAX to turn back on. I don't usually let it get so low that it just shuts off but, that's what I did. I charged it overnight & now, it won't come back on! HELP!
lenna.corwin さんによる
