メインコンテンツにスキップ
dishwasher motor connection 110v
hi. all...
i have a dishwasher motor and i want to use it to make a cheese grinder, so my question is how to connect with 110v direct to work... the other piece with the white plastic i don't need.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
7 件のコメント
it come out of G&E DISHWASHER..CAN I REMOVE THE SOLENOID OR NOT..
さんによる
Give us more info on the motor itself. Yes you should remove the solenoid etc. Since it appears to be a pump there should also be an impeller at the end of the shaft etc. Post more images of your pump. right now it looks like the motor connects to the pump housing via the screws on the top corners. So, the solenoid and the motor are connected to the pump housing. You may have to remove it, but it will depend on the design of your cheese grinder.
さんによる
I going to remove the solenoid and the white plastic and the side pice, so if I connect the power on the top connecter you think it should work,
さんによる
That is the way I would proceed.
さんによる
OK, i try tomorrow to connect the power??
さんによる
2件以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
vitodeluca, it might help a bit more if you tell us what model motor this is and/or what dishwasher it comes out of. Right now it looks like the Recirculation Pump motor. The part on the left looks like the solenoid to shut the flow of. The AC (power)connections are the once above the thumb in the picture.
update
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
vitodeluca さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 287
