Why will my PC not boot from SATA Solid State Drive
I upgraded by adding a SSD via SATA port on the motherboard. It works fine but will only boot if I also have a (redundant) operating system (Windows XP) on the original IDE drive. I can then choose to boot straight from Windows 7 on the SSD. Without the IDE drive I get a boot error something like Primary Hard Drive Not Found.
The IDE drive has now developed a fault and I want to install a new hard drive on the other SATA port rather than replace with in IDE drive.
Can anyone offer advice? DM.
この質問は役に立ちましたか?
2 件のコメント
All done and working, thanks.DM
Delta Mike さんによる
cuando prendo mi pc,, me dice que no tiene dusco duro por que, si solamente lo quite para checar otra computadora y al insertalo de nuevo me aparecio que no tengo disco
Andree さんによる
