screen crack but phone works fine
Do i need to replace the lcd screen only or lcd screen n digitizer
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You should replace the digitizer and glass as they tend to come as one unit and it is harder to remove the digitizer from the glass. Here is a how too video.
https://www.youtube.com/watch?v=vz2lblnG...
an Idea of price from amazon
http://www.ebay.ca/sch/i.html?_odkw=Sams...
Hope this helps
このアンサーは役に立ちましたか?
you do not need to replace the LCD if it still works the LCD can be pricey for this unit
you only need to replace the screen and not the digitizer. be careful though it is extremely easy to damage the digitizer while replacing the screen if you are not careful. make sure if you do it yourself do not use too much heat and when getting the glass off use something like a playing card to get under it so that you do not damage anything. good luck with your phone
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 107
