メインコンテンツにスキップ
Manufactured from 2004 to 2009, the Vino 125 has a 125cc engine.
18回答 すべてを表示
no electric to horn, lights, and starter
tried to start scooter after a long winter, but nothing. tried charging the battery, and still nothing. replaced the battery and still nothing. no lights, no horn and no attempt to start even with a new battery,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
1 件の回答
最も参考になった回答
sandycav, check the wiring on the battery connectors, make sure they are nice and clean. Your scooter has a main fuse in the power line. Check that one for continuity and make sure that you have power going to the fuse. If all that is okay, use the attached diagram to check for power. You will of course need a multimeter for that.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks! I've visually checked the fuse yesterday and it looked ok. I'll get a multimeter and try to check from the battery out.
さんによる
コメントを追加
回答を追加する
sandycav さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 74
今までの合計 5,453
