iPhone got wet, now the touch screen doesnt work...
iPhone got wet.. I got it to work but last week the botton part of the touch screen doesnt work anymore.. what do I do?
PLEASE HELP! Apple want to charge me $199 to replace it
since you didn't wrote anything about cleaning - i guess you only let it dry. that means that parts inside the phone are shorted and that could lead to your problem.
the only thing i can recommend is a good cleaning with isopropyl alcohol (>90%) and a soft paintbrush, clean the logicboard and the connectors carefully - but the white/greenish residue has to be removed. let it dry and reassemble it
nevertheless - the touchscreen could be toast. but that call can be made after you cleaned everything.
good luck
このアンサーは役に立ちましたか?
I bet the cables are corroded
take a pic of the inside so i can help you better
このアンサーは役に立ちましたか?
I will, thanks
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,915
