メインコンテンツにスキップ
A Makita angle grinder released in June of 2010. Model number GA4030K.
What is causing my angle grinder to make so much noise?
For the past several days I have been using my Makita GA4030 to work on an extensive project for many hours at a time. As I was using it this afternoon I noticed that the grinder started making a funny noise that it has never made before. What’s going on? Is this something worth fixing or should I just go buy a new one?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
When you dropped the angle grinder, you may have dislodged or broken some internal components. To find the problem, open up the angle grinder and look for damage and loose pieces. Damage could take the form of dents, unconnected wires, or loose graphite bits within the device.
The angle grinder is fixable - visit the ‘switch repair’ link on the troubleshooting page found here:
Makita GA4030K Troubleshooting
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Nyssa Backes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 4,431
