メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fujifilm FinePix XP50は、過酷な環境下での使用にも耐えられるよう設計されています。本デバイスの修理は難易度が高く、プラスドライバー、六角ドライバー、およびリペアツールが必要です。
Why won't my camera turn on?
Why won't my camera turn on when I press and hold the power button?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 7
2 件のコメント
Mine wont turn on either, the battery is fully charged and inserted properly. I can tell this as the pre-flash light comes on but nothing else, the only way to get the pre-flash light off again is to remove the battery.
さんによる
my camera come on then tells me to turn on and of again .please help
さんによる
コメントを追加
2件の回答
ベストアンサー
The camera most likely will not turn on because the battery is dead or because it has been inserted incorrectly. Try recharging the battery and then carefully inserting the battery back into the camera. To insert the battery correctly match the orange part of the battery with the orange part of the camera.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I double checked and insert the battery, press on, but still doesn't work.... but it does make a dot dot dot sound.... Plz help
さんによる
It tried to turn on once, then left the lens extension out. That was the last time it turned on. I have tested the batteries, they are all testing charged. I have a FinePix S2940WM #1TD82038
さんによる
I ordered a new battery for my camera, thinking that was the problem. I inserted the new battery and nothing happened. I even put it on the charger and let it sit for about 30 minutes and still nothing. Also, how do I charge the battery? I understand plugging my camera into the cord, but is there a different way?
さんによる
Thank you so much!! My battery inside my camera, was just turned the other way around. It was just newly purchased and was second hand so I thought something might've been wrong about it. I'm so glad I found this post!!
さんによる
コメントを追加
I noticed environment temperature affect this - a month ago it could be turn on in temperatures below 20°C, now it requires below 18. But (1) I cannot take a refrigerator with me, and (2) after taking it from the refrigerator water wapor condensates on it, especially on optics, making it unusable.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Matt Wilborn さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 67
今までの合計 16,394
