メインコンテンツにスキップ
本製品は、2010年7月27日にAppleから発売された解像度2650x1440ピクセルの27インチLEDディスプレイです。モデルナンバーはA1316。
78回答 すべてを表示
Display flickers briefly then goes black after connecting mini dp
The display was working one night just fine until we restarted the machine. When the machine booted up, the display remained black.
I tested it on a macbook that is working with another cinema display, but nothing happened. I opened up the broken display and reattached the cable connecting to the function port on the logic board. After trying it again, it would flicker and I would see my desktop for a split second before the screen goes black.
The display is detected, is able to charge my laptop, and the rear USB ports are also working. The display will flash and show my desktop every time I reconnect the mini dp.
Any thoughts on what could be faulty here?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
6件の回答
最も参考になった回答
Got the same problem. I solved it by buying a outlet switch. If you turn the screen off and on for a couple of times the picture will stay and keeps on running till you switch of your machine. So it's basically just a starting problem. Somestimes it takes about 5 min until the screen finally stays on - sometimes it works at the first time. I heard from an tech student that it's related to the logic control of the screen. So he said if I want to fix this I should buy another screen panel - not the logic board, because the logic control is in the screenpanel. At least that's what he said. I took the cheaper option and just bought an outlet switch for 2€ :)
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
by the way: my screen was an ebay luck shot for 50€
さんによる
Thank you, thank you, thank you!!! Had the exact same problem and solved it by switching my Apple Cinema on and off several times.
さんによる
コメントを追加
Can you shine a flashlight at the display at an angle, do you see a faint image of your desktop? If you do then the backlight WLED driver is likely blown.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Hi @danj, how would you go about replacing the backlight WLED driver on this display?
さんによる
コメントを追加
I have the exact same error, but it's intermittent and the problem mostly arises after power has been entirely disconnected from the display, i e disconnecting the power cable or switching an outlet off. As long as the computer just sleeps the display, it will often start up again.
When I get the flicker problem, sometimes one of two things helps to get it running again:
  • Connect it to a laptop and adjust the brightness setting of the Cinema Display. Results may not be instant, and doesn't always work but often does. You can try to lower it, then crank it up to max. (Note: the USB cable needs to be connected for the brightness setting to appear)
  • Like @janoslinde has done, connect it to an outlet with a powerswitch and try to power cycle it there. Often works for me.
  • Connected to a Mac mini that can be forced turned off, the display sometimes comes alive when cold starting the Mini again (this seems to give the display a different type of signal than when the computer sleeps and then wakes up)
At this point, I'm considering
  • Changing the logic board (around 120-200 EUR on eBay)
  • Getting a new Backlight WLED driver like @danj suggested
  • Changing the power supply (although multimeter reading shows it gives 24V, 12V, 5V, 3.3V just like it should). However it may be unstable, maybe some of the condensators bad? Costs around 100 EUR on eBay.
  • Possibly buying a new Function and/or Backlight cable (internal cables) although it seems unlikely it would be damaged and suddenly (and temporarily) go bad as to shut off the backlight.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Added info: Actually when using the screen with my MBP, the screen was on for several hours but flickered (200ms flickers) twice during this time. Then suddenly it just went black.
I opened the display to test for 24V (which is supposedly driving the backlight), and it was still present. However, I may want to test for DC Amperes, since Volt doesn't give the full truth. I guess a bad capacitor on the PSU could still give the right volts, but not the right amperes.
さんによる
What finally worked for you to get your monitor fixed? Was it the control board? I am having the same issue with one of my A1316 Cinema Display monitors.
さんによる
Daniel, sorry for my slow response. Unfortunately the display was never completely fixed - I tried replacing the PSU, logic board and all-in-one cable, but it didn't make the issues go away.
さんによる
コメントを追加
Hi,
Same problem.
I tested your different options (replugging many times the power screen after 2s or 10mn) without any success.
But I was interested by the idea of “sending a different signal to the screen” to get the light back.
So I plugged the screen normally to my MacBook and I reset my NVRAM / PRAM (Turn on your Mac / press and hold the Cmd+Option+P+R keys immediately after your heat the startup sound. Hold these keys until the Mac restarts and you hear the sound again)
And during the reboot, the Led Cinema Display turn on normally
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The power supply board may also be going bad. Does it work if you unplug power for a few minutes and then plug it back in? Usually it will work for 2-5 minutes and then the display will go black again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Sounds like the same problem I had. See:
What components need replacing on the Logic board?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
joro126 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 49
今までの合計 7,086
