adjustment of laser lens
i can't find the screw for adjusting the lens
It should be under the DVD drive, on the board or laser. It will be in the form of a trimpot. This can fix DRE's but doing it too much can ruin games by literally burning them. Don't do too much or too little. Strike a good balance and leave it.
Cleaning the lens might help too. Trimpot work is a last resort known to fix this problem.
このアンサーは役に立ちましたか?
i always use microfibre cloth (it's a special one to polish glass) - i only breathe on the lens and then polish it - thats all, no alcohol needed (ok, only afterwards a good cold bavarian .... ;-)).
このアンサーは役に立ちましたか?
the best for you is just to clean the lens after cleaning the lens clean the disk drive and blow all the dirt inside that all
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 2,118
