メインコンテンツにスキップ
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
84回答 すべてを表示
Screen flickers for half a second then goes blank.
I just found a LED Cinema Display during spring cleaning that is not entirely working. The audio, charger, and usb all work on the display. The screen is detected by my 2011 13 inch MBP. About 40% of the time when I plug the thunderbolt cord into my laptop the screen will flicker for a half a second and then go completely black. I used my flashlight to look at it and I do see my computer's desktop on the display. From what I can see the backlight isn't completely broken, I figure it is either a problem with the thunderbolt connection or the logic board.
Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
Hey, did you ever get this fixed? I have the same exact issue.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Sounds like you have a cold solder joint on the logic board on the backlight WLED driver or the driver it's self is blown.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks Mayer! Good vid on cold solder joints.
さんによる
コメントを追加
回答を追加する
crennie123 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 2,955
