メインコンテンツにスキップ
2012年10月23日に発売されました。Core i5もしくはCore i7プロセッサ、Apple Fusion Driveを搭載しています。
20回答 すべてを表示
Could I add water cooling to the system?
Would it be possible to retro fit a corsair h80i onto the mac mini if it were in a separate enclosure?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Why do you think you need to do this?
さんによる
Just for fun and better cooling mostly for fun.
さんによる
コメントを追加
2件の回答
ベストアンサー
Seth Potter, can it be done? Sure it can but will require some ingenuity on your part. Check on here for some fun reading.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
I agree with oldturkey03 on this one it can be done but not in the enclosure provided by Mac . so if you do it , it will no longer be a Mac mini and therefore defeat the purpose of having a Mac Mini. So with that said I also agree with Dan in that its not possible
さんによる
I don't use the mini because it is small mainly because it is cheap and i already have a monitor that I love so the imac doesnt make sense thank you for your response
さんによる
コメントを追加
Sorry, not really possible. It would require a major overhaul of the case to get the modified logic board to even fit.
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
Stick in the mud ;-(
さんによる
Won't really improve things from a performance perspective. Remember the CPU & GPU is mounted on the bottom side so you would have issues mounting the drives as it would interfere with there mounting.
さんによる
He could put it on an inch thick piece of plate steel and remove the feet, insert some long metal pegs for feet (as the bottom is plastic. Put a bobble head Steve Jobs doll on top.
How about drilling a large hole in the back and hooking up a shop vac?
Put it in a rack holder: http://www.sweetwater.com/store/detail/R...
さんによる
Ha! You're just getting weird on me Mayer ;-}
We use shelfs in our rack to hold a few which are RMON probes as well as using WireShark (Ethereal) to monitor our network.
さんによる
Silly questions get silly answers ;-)
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Seth Potter さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 2,599
