メインコンテンツにスキップ
Released in January of 2013 the Canon Powershot, model number A2500, is a 16 Megapixel digital camera. This camera can be used to take images or low quality videos.
How do I delete all images on an SD?
I want to wipe the SD, but I don't have a connector to plug the SD on a computer. I prefer not to have to delete the images one-by-one on the camera. Is there a way to delete all data on an SD? If so, please help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi Victoria,
In order to wipe your SD from this model camera you must turn on the camera with the SD Card correctly inserted and then press the menu button. Then scroll to the right so that the wrench and the hammer tab is now highlighted. Now scroll down to "Format..." and select it. The menu will now prompt you to format the memory card, press OK twice and your memory card will be wiped.
For any further issues visit our Canon PowerShot A2500 TroubleShooting guide. Where there are guides for several other common problems.
Hope this helps,
-James
このアンサーは役に立ちましたか?
スコア 13
7 件のコメント:
what does scroll to the right mean? What or where am I supposed to scroll?
さんによる
James, Thanks so much for explaining how to erase images from camera. It worked perfectly for me on my first attempt. SUPER EASY! (Once you know how) lol
さんによる
How do you press the "OK" button?
さんによる
How do I take a picture without using the flash please?
さんによる
What do I need to do if the "format" section is not highlighted like the other selections and does not respond to clicking on it? Victoria
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Victoria Winters さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 22
今までの合計 18,787
