Why won't my laptop charge?
My HP ENVY dv7 won't charge. I have taken out the battery, used multiple wall sockets, used two different cords and it will not charge. What should I do?
Does it turn on when connected to power cord without the battery?
このアンサーは役に立ちましたか?
If it does it sounds like a defective battery and seeing as your laptop is relatively new it may still be under warranty.
I also found out what the solution is!
On the mainboard (near the power connector) is a TI chip (Texas Instruments), identified as BQ 24740. (Texas Intruments part # BQ24740)
This is the battery loader and power control chip.
It is easily destroyed by a weak and flimsy external power supply, like what is delivered with HP products.
The DE-soldering and soldering is tricky, because it is a QFN package, and very small.
It solved my problem for just $ 8for the chip and $60 for a local shop to install
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 784
