メインコンテンツにスキップ
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418回答 すべてを表示
締切られた回答
Display affected by hinge
Backlight goes off but you can see the screen with strong external light.
Backlight can be invoked with a magnet placed on the desktop.
Started with recovery done by rearranging the cover angle. Thought it might have been the cable within the hinge until I saw the magnet work. Stays on momentarily and then it reoccurs.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Thanks
I reviewed and see that I have an A1181
does this fit apply to this model. I see that the infrastructure is different? 2009
さんによる
Yes, it does make a difference ;-}
さんによる
コメントを追加
1 件の回答
最も参考になった回答
If the screen goes dark again after placing the magnet on the top where the sensor is that implies the hall sensor is bad. If I remember correctly, the hall sensor is part of the hard drive cable. Here's the IFIXIT guide to replace the cable: MacBook Unibody Model A1342 Hard Drive Cable Replacement.
It is also possible the WLED driver has a bad solder joint. But that is a logic board level repair. For now try the cable and let us know how it goes.
Update
You'll need to replace both the inverter and the invert cable.
Here's the guide to follow: MacBook Core Duo Inverter Replacement & MacBook Core Duo Inverter Cable Replacement
MacBook Core Duo Inverterの画像
ガイド
難易度:
難しい
1 - 3 hours
MacBook Unibody Model A1342 Hard Drive Cableの画像
ガイド
難易度:
中レベル
10 - 40 minutes
MacBook Core Duo Inverter Cableの画像
ガイド
難易度:
難しい
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
OK, Nix the drive cable. Your system has an inverter which is likely the issue
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 82
