メインコンテンツにスキップ
Xbox 360は、2005年11月22日に発売されたMicrosoft製第二世代ゲームコンソールです。
428回答 すべてを表示
My xBox keeps switching itself off after 5 minutes.
Im wondering if anyone has any ideas about this.
I was given an xbox 360 for free a few months ago by a friend who said that if i can fix it i can keep it, and now im losing my patience with it.
After 5 minutes after switching it on, it just switches itself off again. I have opened it and cleaned away all the dust and grime (there was lots) from all the components in the inside.
I am not very technically gifted so i would appreciate a bit of help.
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
Sounds like a overheating issue.
Is the fans running?
No: Why?
Yes: Good
Is the console old?
Replace the thermal paste.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
放熱グリスの塗布方法
Read this guide about replacing therman paste.
As to how to open up the xbox 360? I'm not sure, haven't done it before.
さんによる
the console is a couple of years old. the fans sound as if they are trying to make the console take off.
さんによる
Have you played on an xbox 360 console before?
They are loud.. Mine sounds like an jumbo jet taking off, and it's perfectly normal... Once it start sounding like an F22 jet-fighter I'm going to replace my thermal paste.
Just a thought
さんによる
no i havent played on it before because it was given to me broken. I fixed the thermal paste problem but now when i switch it on i have a 3 light "ring of death".
any suggestions?
さんによる
Maybe you spilled some thermal paste on the cpu? That could cause some weird errors.
The three lights is probably some sort of error code. Sadly I wasn't able to find out what it was.
さんによる
コメントを追加
may be like rousp said the fans are not working or u need to take it apart an use some computer cleaner,duster,my old 360 did that it was the xenon chip now i have the falcon chip one it works well but the disc tray wont open some times i have to use contact cleaner on it but a few days later same prob i tap on the top to get it open,good luck there a pain to take apart all the screws an the removal of top an bottoms a pain it takes time an some skill.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
http://www.se7ensins.com/forums/threads/...
solves your issues, trust me ;)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
wazzzat, did your xbox not stop functioning shortly after the repair from that link? Does not sound like a good repair, does it?
さんによる
コメントを追加
回答を追加する
Paul さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 9,784
