メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kodak EasyShareのトラブルでお困りですか。修理ガイドを確認して、再び美しい写真を撮れるようにしましょう。
Why won't the camera turn on?
The camera will not turn on no matter what I do.
I press the power button and the start up noise and start up display screen do not appear.
What can I do to make it turn on?
Please help me out,
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Hello there!
If the camera doesn't seem to be turning on, it may be possible that the battery has lost its' charge. If you can locate the charging device that came with the camera, you can place the battery inside of it and allow it to recharge for a few hours. Hopefully this does the trick! Comment on how it went!
Good luck!
Caitlin
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
try blowing compressed air into the optical lens i had this issue were the lens gets jammed and it prevents from fully opening my would shut off put some air through that area and presto. eventually had to tear down the camera to completely clean it but hopefully that is the issue with yours. Good Luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Elizabeth さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 27
今までの合計 2,797
