メインコンテンツにスキップ
Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
98回答 すべてを表示
締切られた回答
Makes 1st cup then will not pull in water from reservoir
My Keurig atuo powers on in the morning. The first cup brews as normal. Water is pulled in from the reservoir and it dispenses a full cup. On the second cup, it makes the motor sounds like its pulling water from the reservoir, but no water is pulled in. Then the blue lights blink as if the reservoir is low, but in fact it's only missing the water from the first brew. Next day it will do the same thing. Cannot get 2 cups out of it when it's heated up.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
It seems to only happen when the maker has been on awhile. If I turn it on later in the day and make a cup right away, it will make more as usual. If it's been on awhile it's like there's a vapor lock and won't make the second.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Brian, check this page. Check for the Water Reservoir Magnet
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 358
