メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HTC Desire 816は、1280x720解像度の5.5インチディスプレイ、13MPのリアカメラ、そしてHTC BoomSoundを搭載しています。
Why doesn't my touch screen respond?
tounch screen of my mobile htc 816 does not work. I bought my mobile from 3 weeks and I do not know the problem come from
Please help me to find the prolem if it is hardware or software
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 21
7 件のコメント
me also same problam -htc desire 816 i got before 3 weeks but noe touch screen not working - i am reset the phone also but no sucess. i have to go to seller now
さんによる
My htc also same probelm my screen not working properly
さんによる
my mobile also as like ur problem now what can i do plz suggest me
さんによる
Wow I thought I was only having trouble my HTC desire is not working my screen is fine but no response it sounds more software but let's not leave The hardware out yet until we know sounds like HTC software
さんによる
My HTC Desire 820ts touch is showing problems like if sometimes it does not respond . And also when I tap on one application , it goes to another . Please can you help me ?
さんによる
2件以上のコメントを表示
コメントを追加
15件の回答
最も参考になった回答
A soft or hard reset may fix this problem if it is software related.
To do a soft reset:
If the display is off, press the POWER button to turn it back on.
If you've set up a lock screen, you need to unlock it.
Press and hold the POWER button, and then tap Restart.
When asked to confirm, tap Restart.
If it does not respond when you touch the screen or press the buttons, you can still restart it. Press and hold the POWER and VOLUME UP buttons for at least 10 seconds. It should now restart.
Be sure to back up any data and files you want to keep before you do a factory reset.
To do a hard/factory reset:
Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
Your phone should be set back to factory setting now.
If resetting doesn't get your touch screen responsive then you might have a faulty digitizer or a loose or broken digitizer ribbon cable or connector on the motherboard. The digitizer part of the screen is responsible for sensing touch. If you find fault in the cable you will need to replace the digitizer.
このアンサーは役に立ちましたか?
スコア 12
9 件のコメント:
Superb and thanks dude...Please dont buy this mobile anyone this is very hectic and functionality is very bad.
さんによる
thnku for the suggestion...
さんによる
worst phone ever!
さんによる
I've repaired the LCD + Digitizer with Frame a lot for many customers. Not a single one have come to me about this issue. If your system software is not up to date. I recommend to update it to the latest available update.
The digitizer connection shouldn't get loose. It's held around with grey adhesive tape making it pretty hard for it to come unplugged or loose by itself. Though the other flex cable connecting the digitizer cable to the logic board can become loose in some cases, It has foam behind the cable where it plugs into the logic board.
さんによる
thanx a lot my friend it worked
さんによる
4件以上のコメントを表示
コメントを追加
tap the screen with a hammer as hard as you can
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
my touch screen not working properly htc desire 526. very disappointed with this phone.
さんによる
Lol don't listen to the guy above unless your fed up like me I may take his advice but before we smash our phones try updating software first
さんによる
コメントを追加
my HTC desire 816W has same problem.open automaticaly programs,and now left side of touchscreen is disabled.display is OK.but touch has problem.what is the solution?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
How can you go to setting and then recalibrate on something that is not responding to touch Raguraman?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
No it is not a hardware issue it's a software issue I also feel this issue after updating the latest software of HTC desire 816
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
what software version may solve the issue?
さんによる
コメントを追加
Solution
I also had this problem for quite a while. My phone does give me a headache because I can't always use it (I am getting a new samsung this June) but I have found a solution that works for me. What you have to do is create electricity for the screen. To do this, you create static electricity but rubbing your hand roughly against the screen until it feels very hot and it gets harder for your hand to slide across. This isn't permanent, and you might have to do it every time you pick up your phone, but it works.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
problem in hardwear in htc
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
hello
my touch is not workng
i want to remove pattern how plz help me
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Just switch of the phone and restart if it is not working go to setting and calibrate
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It worked for me . Great thanks
さんによる
コメントを追加
there should be problem in hardware n software to...first let me help with software issue if your touch is not responding swicth on the cell phone and only press switch on button for a long time and after pressing 1-2 minutes u r phone will be restart.....than it problem will be solved.....if it doesnt than open the cell phone and remove the touch pad there should be a moisture clean that and definetly it work..........**** if u like my answer best of luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
  1. Turn the phone off or remove battery and put it back. 2.Press the volume button to the lowest while you press the start button. Try a few times until you see a strange but simple menu. You can browse with the two buttons. 3. Go for recovery. It takes forever, but usually it works, and you´ll keep everything. In worst case; choose factory reset from the same menu. It´s not the screen.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
And what happens when I press the hard reset buttons and it does not work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my phone htc desire 816 model display screen not working.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I know one %#*@ solution
If you recently changed your screen ,
Keep your screen cool (don't use it in hot surrounding) (like put it in front of air conditionar for few minutes and boom your screen works fine )..it becomes unresponsive when screen gets heated ….its an hardware issue not an touchscreen or software issue ..I have conformed it by myself
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have this problem as well but with the HTC U11. I already changed the screen and even with the new screen the touch is unresponsive. Does anyone know what may be the problem, or how I could fix this?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lubna ibrahim さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 16
今までの合計 66,054
