メインコンテンツにスキップ
The Microsoft Band is a wrist tool and accessory with a rectangular LCD screen on one side of the device and a heart rate monitor on the other. It can be paired with a wide variety of smart phones. The model number is 1619 and is written in fine print next to the two hooks that clamp the band shut, or written on the bottom of the original packaging.
How water resistant is the Microsoft band?
I accidentally dropped the Microsoft Band into water. It seems to be working, but should I still be worried?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
The Microsoft Band isn't completely waterproof. Though it meets the IPX7 standard in testing, the Microsoft Band is not intended to be immersed in water and immersion is not covered by the warranty. Light rain or hand washing shouldn't harm it, but immersing it in water can damage and impair the screen, microphone, and batteries. Try not to wear it when you're swimming, washing dishes, or taking a shower. You can replace the damaged parts by following the guides for the Battery Replacement, the LCD Screen Replacement, or the Sensor Ribbon Replacement.
Additionally, if the Microsoft Band is dropped or receives an impact, its water resistance may be impaired or weakened. Take care to avoid sudden shocks.
Microsoft Band LCD Screenの画像
ガイド
Microsoft Band LCD Screen Replacement
難易度:
中レベル
10 - 15 minutes
Microsoft Band Sensor Ribbonの画像
ガイド
Microsoft Band Sensor Ribbon Replacement
難易度:
中レベル
15 - 30 minutes
Microsoft Band Batteryの画像
ガイド
Microsoft Band Battery Replacement
難易度:
簡単
10 - 15 minutes
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Do you know where I can buy finishing parts to microsoft band? It is the part that protects the battery (which has screws). It is whole peeled from my use. It is easy to exchange but I don't know where can I buy these two parts.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hello Fernando,
Unfortunately, at this point we can't buy any specific parts of the Microsoft Band. This is because the Microsoft Band was just released recently and its manufacturing process doesn't allow us to access its individual parts. Eventually, however, you will be able to find the components of the Microsoft band online.
さんによる
コメントを追加
回答を追加する
Monique Salinger さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 1,962
