メインコンテンツにスキップ
High-end gaming laptops produced by Alienware (a subsidiary of Dell since 2006).
139回答 すべてを表示
My laptop won't connect to wireless
for some reason my laptop won't connect to my wireless connection . please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Have you turnt the wireless on and off? Is the router turnt on? have you tried connecting via ethernet? Have you updated the driver?
さんによる
Do you have anything else that can connect to the WiFi AP? If so the issue is within your laptop. Check your settings comparing them to your other working systems.
さんによる
are you able to see if the wireless card detects your SSID and others?
if so, first remove the driver (if windows asks delete files say no) an re-scan for network devices. Try to connect and if you can't run anti-virus software. Malware and avast i recommend.
さんによる
コメントを追加
4件の回答
最も参考になった回答
thats very easy just go network settings and check the driver and update it or reset it make sure the router password and you are set for more visit http://support.alienware.com/Support_Pag... i hope that works . thanks
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I know this my seem like a long shot but try holding fn at the bottom left of your keyboard then hitting F3
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Dude thanks helped me out
さんによる
OMG thank you!!!!!!!!!!!!!
さんによる
You sir, are my life saver. Standing ovation to you.
さんによる
For me it was f2! I had tried a new card, a usb wifi connection and even reinstall of os. Nothing worked! I must have bumped those keys when cleaning my keyboard.
Thank you to this site and the forum as well.
さんによる
コメントを追加
First check if the WiFi card drivers are up to date and working properly. If they are then check the WiFi card is properly connected to the motherboard, and if it is connected well and still not working then you have to replace the WiFi card. here is the guide Alienware M14x R2 Wi-Fi Card Replacement
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
i will assume u are using windows. can you see if the wireless card detects available connections?
if yes, uninstall the driver, re-scan for hardware (or re-start), windows will re-install the driver, try again or do a diagnostics first.
if not, run anti-virus software and also try wire (as already suggested by a previous answer) to see if you can get an ip to connect to the internet.
P.S It would be good to know the OS so when i answer i can give you more tips. e.g like run msconfig and disable all entries except microsoft.
Also start in safe mode with networking.
if you have windows 10 (i can give you the instructions to get in safe mode but i don't want to confuse u) so you can google for this so while at ur pc you can follow the instructions.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
nene parkar さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 15
過去 30 日: 82
今までの合計 25,892
