メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
What are some solutions if restored the computer before replacing the
After restoring the whole computer and deleting everything on it, as I was about to reinstall Os X Mavericks again, the hard drive would not appear. It is because before in disk utility it said that the s.m.a.r.t. status is failing. If I replace the old hard drive with a new one, how do I format it so that I will be able to install Os x Mavericks and startup my laptop brand new again?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
https://www.youtube.com/watch?v=0K82njig...
I found the steps just in case anybody else has the same question ^
さんによる
コメントを追加
1 件の回答
ベストアンサー
Internet recovery is great if you have a good and fast connection. Sadly, most people don't. It also can be expensive if you are using your cellphone hotspot function. Lastly, not all of the Mac's have the ability to use this service even with the newer OS's (older models).
This is were being prepared ahead of time can save you time & money! At home I've already created a bootable USB thumb drive which also holds the OS installers as I upgrade the OS on my systems. That way I don't waste time trying to rebuild my system or even to maintain it (running Disk Utility and HD defrag tools as needed)
If you have a friend who has a Mac you should be able to setup a USB thumb drive as a bootable drive using Disk Utility & OS Installer already on his system. Once the USB thumb drive is prepped, you should be able to copy over the OS installer app onto the USB thumb drive to boot up your system so you can prep and re-install the OS once you use it to boot up your system.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
This might be a dumb question, but would an external hard drive work instead of a thumb drive?
さんによる
Yes! it is just as good! The issue is mostly cost and size. Thumb drives are cheap and you can have a bunch setup with different OS's and tools. If you can get a Thunderbolt Hard Drive (or for older models FireWire) as the I/O speed is much faster than USB port these systems have. That way you're not twiddling your thumbs as you wait for the OS to load ;-}
さんによる
コメントを追加
回答を追加する
milushik411 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 74
