メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Briggs & Stratton製 190cc モデル120000 Quantum 675シリーズ 芝刈り機エンジン。2011年2月発売。Toro製 6.75 ft-lbトルク 芝刈り機用。
Why won't my pull cord retract?
I tried to start my lawn mower and my pull cord remained extended after I tried to pull it. How can I fix this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント
Try spraying WD-40 in the mechanism. You may be able to do it without taking it off the mower. It fixed mine'
さんによる
Hi I have same issue but its when I put the screws back that hold the Assy down it stops working but if I take off it works flawlessly any idea
さんによる
Same issue as Jay hICKMAN
さんによる
コメントを追加
2件の回答
ベストアンサー
Try jerking the cord a little harder a few times and it might retract again. If that doesn't work, please look at our pull cord replacement guide. See if you can find out where it might be stuck to have it retract again. If that is not possible then please follow our pull cord replacement guide and replace the pull cord completely.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
cord will retract when not on mower but when installed will not retract after pulled
さんによる
I have the same issue, I picked up the Cub cadet from a friend of mine. This mower is brand new no oil in the engine. It appears that something quite heavy fell on it
So I disassembled it and I'm in the process of replacing all the damaged parts. The pull cord assembly is just one of the parts. Its a brand new part.
It will work fine until I put the screws in it and tighten it down. I can pry it away from the back of the mower and it frees up.
Any idea what might be going on with it
さんによる
コメントを追加
It is also possible that the pull cord assembly is broken or jammed. You should take the assembly out and see whats causing the resistance.
このアンサーは役に立ちましたか?
スコア 3
7 件のコメント:
I don't know how to take the assembly out. If I have to take it to lawnmower experts to sort out, is it costly?
さんによる
Where can I buy a pull cord kit?
さんによる
None of these answers help me with my problem. I have a brand new rip cord assembly which works perfectly when it’s off of the mower, as soon as I install it, the cord will not retract. What next???
さんによる
I have the same issue. New recoil which works when it is not installed. Once installed the cord will not retract.
さんによる
sAME, ONLY WORKS WHEN NOT ON THE LAWNMOWER
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Tim Wirtz さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 57
今までの合計 72,279
