Lets put your computer back together so you are back with the white screen with the question mark.
Once you get to that point we are very close in getting things working.
OK, now we need a bootable drive to finish the install. Is the HD you took out working? If so we could use it. In this case you'll need a SATA to USB adapter cable like this one: USB 2.0 to SATA/IDE Combo Adapter. Using it we can boot up your system to finish the process.
If you don't have a working drive you'll need to create one. Using a friends Mac and a USB flash drive you can use the OS installer to install a bootable OS onto the flash drive. Then copy over the OS installer to it and using it on your mac you should be able to boot up your system and then using the OS installer thats on it install the OS onto your new HD.
Sadly I have some bad news here ;-{
Your systems SATA port is only SATA II (3.0 Gb/s). The drive you got a Western Digital Caviar Blue 1 TB is a fixed SATA III (6.0 Gb/s) drive. For your reference click on the link above for your system and here's the drives spec sheet: WD Blue Desktop Hard Drives.
This drive won't work in your system as the SATA I/O speed is too fast.
You also have a second problem here:
This series uses a special cable to access the internal thermal sensor within the HD. You need to use the same vendor of HD as the replacement (Seagate for a Seagate, etc...). So depending on what your system came with you'll need to match up the SAME vendor as the cable is different from vendor to vendor Apple used.
As it turns out you can replace the cable! So if you want to change the drive out to a different vendor you can, its a bit more work and you'll need to order it matching it up to your SATA II drive you are getting.
Cable, Temp Sensor, Hard Drive
922-9223 - Hitachi Drive
922-9224 - Seagate Drive
922-9225 - Western Digital Drive
OK, So far we've gone over why your drive won't work and why your fan's go into high gear.
Lets see if we can find a better drive for you. Again, you do need to match up the vendor unless you swap out the cable.
So lets say you had a Seagate drive then I would go with a Seagate SSHD drive. Here's a description of the drive: Seagate Desktop SSHD, and here is the spec sheet for it: Seagate Desktop SSHD spec sheet. Whats important here is checking out this line: "SATA Transfer Rates Supported (Gb/s)" note it offers SATA III, II & I support "6.0/3.0/1.5" so its a perfect fit for you and you'll get the zip of a SSD and yet the deep storage of a traditional HD.
4 件のコメント
Can you give us the last four digits of your serial number so we can identify which model you have.
Dan さんによる
Bottom of the stand says KDB5
briandholley さんによる
iMac 27" 2.8 GHz i5 (Mid-2010)
Dan さんによる
I have same issue No Display on iMac LCD , but its working fine on external Monitor. Already I have second one (iMac) and I swapped all the parts one by one but the second one still working fine with all of the first one parts and the first one still not display on LCD. ???
faran さんによる
