メインコンテンツにスキップ
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548回答 すべてを表示
Can I upgrade my iMac processor
Hi I currently have a mid 2007 20" iMac with a 2.0 ghz processor.
I cannot play back go pro videos so I upgraded fom 1gb of ram to 4.
Made an improvement on having more than one thing open but still won't play hd vids properly. People say I need to replace the processor. What speed can I safely go up to? Is 2.8 too much?
If I upgrade the processor do I need to upgrade any fans etc?
Also I'm here in the uk so do I need to select a voltage specific processor?
Last question people keep recommending I upgrade to solid storage. Is this worth it
Kind regards
Michael
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Sadly you're between a rock and a hard place here.
You really can't upgrade the systems CPU to one of the newer i5/i7 chips and depending on what you have the highest version of Core 2 Duo your system can support is not worth the slight gains it offers.
While your friend is not far off going with a SSD. Your systems internal I/O ports are limited to one SATA port so you would need to pull out the drive you currently have and then the cost factor of a large SSD would bankrupt you as you need deep storage too.
OK, what to do...
I would recommend upgrading your internal HD for a SSHD hybrid drive like Seagate's as it also will run at SATA I or SATA II unlike most other drives you can get today which are to fast for your system.
Next I would max out the RAM the system will support if I remember correctly you can go to 8 GB if you update the systems firmware.
Other than that you may want to think about upgrading your system to a newer model.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Michael さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 261
