Tablet will not turn on even when plugged in
When I attempt to turn my tablet on, nothing happens. I have left the device plugged into the DC-5V overnight while off and it still does not turn on.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @veteranfemale ,
As it is a new tablet , you shouldn't have too much personal data or downloaded apps stored on it yet, so you could try the standard Android hard reset.
Be aware that a hard reset will erase all your data and downloaded apps. It will restore the tablet to its' factory default condition. It will be like when you first got it.
Make sure that the tablet is actually powered off.
1.Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
(If this doesn't do anything try Power + Volume Down or Power + Volume Down + Volume Up - all 3 together)
2. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
When in recovery mode use the "Volume Up" and "Volume Down" buttons to navigate and highlight what option you need. Press the "Power" button to select the option
3. Next use "Volume Down" button to get to the "wipe data/factory reset" option.
4. Once you have highlighted the "wipe data/factory reset", press the "Power" button to select that option.
5. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is highlighted.
6. Then press the "Power" button to hard reset the tablet.
Be patient. It takes a little while to complete the reset.
If this doesn't work, here is a link to the User Guide which contains the manufacturer's warranty statement (scroll to p.28) which details what you have to do to make a claim for a warranty replacement
このアンサーは役に立ちましたか?
#1 option This worked for me!! My laptop turned on!!! Thanks!!
Option 1 worked i had to hold both the volume down and volume up buttons + the power button. Thank you
How do I Do the reset with a iview laptop?
This worked, I held the volume up and volume down with the power button. Thanks
I know f4 but which is down volume. I can't get blue light on key board to cut off ive only used it new for 1 month or so help.....
First, try using the micro USB port to charge the device, then try turning it on again.
If your device still does not turn on, it is possible you have a problem with the display. Does anything show on the screen when you try to turn it on?
There are two possible solutions:
1. If the display is not working, open the back of your device and check if the ribbon cable running from the display to the logic board is securely in place and not damaged. If it is not damaged, then you may have a faulty display and it will need to be replaced. The digitizer and LCD display are not fused together on this device, so this is a fairly easy fix.
2. If the display is working but the device wont boot up, then the logic board may be the problem since it passes and processes all information to the display and from the touchscreen. The logic board is slightly difficult to replace because it could involve soldering. If you look online you may be able to find someone selling the logic board with all the parts attached to it already. Others you might find are missing just the battery. In this case you will have to de-solder your battery and solder it to the new logic board.
The iVIEW-754TPC troubleshooting page is another place you can check out if you are still having problems.
このアンサーは役に立ちましたか?
My tablet does not move from the I view decal
Adesso does NOT support this product any longer and discontinued it several years ago. They have no similar replacement for it, so we're all out of luck! Probably best to tear into the device and do what repairs you can. Not a satisfactory response from Adesso, to be sure!!!!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 11
過去 30 日: 44
今までの合計 27,453
7 件のコメント
This is not working even though I tried it
Avè Ngesi さんによる
por favor preciso de ajuda com meu Viewsonic G Tablet o touch não funciona então não consigo ativar depuração de usb tento fazer hard reset mas não consigo mover para opção desejada nem dar ok não sei mas o que fazer ja que ele so liga e não atende a nenhum comando e ainda mostra a seguinte mensagem Infelizmente, o processo com.android.systemui parou o que eu posso fazer?
tanea massuda さんによる
Thank you thank you I have a iview maximus it would not turn on. The light was green on top but where I plugged it in at was red. I turned my laptop off did what you said held the volume up which is the F4 key and my power button is on the right side. Held both together and poof my laptop came on. Thank you so much for helping .
Judy bug さんによる
My I view will not type letters
Ethelyn Taylor さんによる
I received the iview Maximus 2 as a gift.. and 3 years later it dies on me literally it did I did what we all do maybe it's the charger change chargers let it charge up overnight it turned on the screen went black no introduction no presentation of its saying IVIEW absolutely nothing took it to the repair shop it's stood there for three and a half weeks they told me that the circuit of the motherboard completely and that there was going to cost me more than the laptop itself.. now I don't know what's the price value of this gift but the price range that they gave me to repair that motherboard and keyboard itself was going to cost me nearly $700 and that's with parts and labor.. so now I'm stuck with a useless laptop
mariachicago59 さんによる
2件以上のコメントを表示
