Why is my tablet not turning on?
I tried to turn on my tablet and it doesn't respond to the power button. I have not used it for a while, but the last time I did, it worked perfectly.
In most cases, the battery is just drained. Charge it for a little while, maybe a minute. Then, turn it on. If that doesn't work, the cause could be coming from the power button itself or the battery. This link provides a more detailed approach to troubleshooting the problem you're having: Nobis NB07 Troubleshooting.
このアンサーは役に立ちましたか?
this did not help me at all , and it did not work I am still having the problem . Do I need to have the software installed all over again ? my warranty is old what do I do?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,415
my tablet only stays on the GO Screen that's it . It won't go the Icon's desktop screen
rcleggett さんによる
Why doses this tablet don't shut down I have to hold it for it to turn off and when I turn it on I have to re enter everything back on and not using it I turn it off same thing have hold it than want use it
It not save
annievvtait07 さんによる
Same problem it stucks on the go screen image .I Waited patiently for long time but there no change.I also did reboot and factory reset but there no change it says updating ...I Waited for this also patiently.I Waited for 3 to 4 hours no change....
Is there anybody to solve my problem...
Please help.I will be waiting for your answer....
arshaqsk さんによる
