メインコンテンツにスキップ
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312回答 すべてを表示
internal microphone pin assignment on MBA 1,1 (Early 2008)
does anyone know the internal microphone pin assignments for apple early 2008 macbook air 1,1?
I understand from ifixit pictures the mic is connected to logic board; I ask about pin configs because I'm trying to make mic work under linux, and alsa needs to know about VREF and similar stuff, which apple doesn't make public (notice audio, except mic, works fine in linux)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Alvaro, you mean information like
pin 1
PP3V3_S3_MIC_F
MIN_LINE_WIDTH=0.20MM
MIN_NECK_WIDTH=0.20MM
VOLTAGE=3.3V
Pin 2 and pin 3 NC not connected
Pin 4 AUD_MIC_DATA_F
update
Pin 5 AUD_MIC_CLK_F
Pin 6 GND_MIC_F
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Hi, thanks for your help.
My goal is make the internal microphone work in Linux. Since this is both the only audio part not working and the only one connected to logic board instad of audio card, I suspect I have to instruct linux kernel, in particular alsa, how to use this device; and in order to do that, usually some VREF, GPIO or other pin assignments are required, even though I'm not completely sure which ones; in particular I'm not sure whether we need to modify the ALC 885 codec part, which is in the sound card, or we need to look for a different device/codec.
Are the ones you posted the physical pins from mic cable to logic board plug assignments?
さんによる
Those are the pinouts from the connector on the logic board.
さんによる
thanks, let me see if those help
さんによる
Hello. I was thinking again about this problem. It is indeed true that mic is connected to logic board, but then it is very likely that via the logic board it's signal is sent back to the audio card, so my question more specifically regards the pin assignment for the mic connection on the realtek alc 885 chip on board the audio card: do you posses a similar picture or data for that?
さんによる
namely (I guess) the right part of the above picture,?
さんによる
コメントを追加
回答を追加する
Alvaro さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 139
