メインコンテンツにスキップ
Samsung Galaxy Alphaスマートフォンは、2014年9月に発売され、Samsung Galaxy Alfaとしても知られています。 Androidオペレーティングシステム上で動作し、ほとんどの主要な携帯通信事業者によってオペレーションしています。
20回答 すべてを表示
Why is there no sound coming out of my phone?
When I try and watch a videos on my phone there is no sound coming out of the speaker.
What can I do to fix this?
I really would like to hear my friends singing happy birthday to me.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 131
31 件のコメント
Check that your phone Volume is Up, that your phone is NOT on Do not Disturb or Silence, and make sure your Bluetooth or any other Casting is turned Off.
さんによる
There is no sound coming out of my phone at all!
It's really stressing me out...
I have turned on everything but still no sound ARGH
さんによる
Please help me my Samsung. J3 when some one call me i can hear when my phone is ringing i cant even look a video on my phone
さんによる
candice and @carolbroer you need to follow the advice given in the answers section or start your own question. this problem has been solved.
さんによる
Yes, see the previous ansawer and I would also add- go into "settings" and check the "sound". Slide the "volume" to the right to increase, especially for "media".
さんによる
26件以上のコメントを表示
コメントを追加
21件の回答
ベストアンサー
There are several problems that could lead to this. First and foremost, we need to check if your sound is on. To do this, while in the video press the topmost button on the side of the phone. This should trigger a display on your phone to show that the volume is going up.
If the display shows, but there is still no sound, make sure there is nothing in the headphone jack that could be redirecting the sound. This means that you can't have any headphones or charms inside the jack, otherwise the sound will be directed through them.
After trying both of those things with no luck, try to see if your speaker works at all. With the ringer volume all the way up, have somebody call you and check if the ringtone makes a noise. If not, the speaker is most likely the issue and should be replaced.
For further help try looking at the Troubleshooting page here: Galaxy Alpha Troubleshooting
このアンサーは役に立ちましたか?
スコア 69
27 件のコメント:
Weirdly I had this problem for several days but just fixed it. I decided to follow the advice on this page and take out my battery and check for water damage. No damage I could see. I put the battery back in and turned phone back on and low and behold sound now works. Weird but very pleased now!!!
さんによる
took your advice breeiejo. took out my battery to check for water damage. No damage I could see. I put the battery back in and turned phone back on and low and behold sound now works. So relieved! Only had it a couple of days.
さんによる
Turning off Bluetooth fixed this pesky problem for me...thanks for ideas
さんによる
I had the same as Breeniejo - just took the battery out and placed it back in and it works !
さんによる
Thank you for helping me resolve my issue. I am not a WIZ when it comes to technical issues on my phone, nor my computer. I sure appreciate it.
さんによる
22件以上のコメントを表示
コメントを追加
i had this problem and it turned out my bluetooth was on and connected to a random nearby device
このアンサーは役に立ちましたか?
スコア 19
8 件のコメント:
Resrart, removed battery & put back to reset, turned off bluetooth.... bluetooth remedy fixed it ( barring drops, etc)
さんによる
Dolby digital plus had my sound muted. Restarted Dolby digital sound in Settings, Sound.
さんによる
It turned out to be a blue tooth issue with me as well. I have a lot of blue tooth items in my home. I disconnected and all went well. That explains why I get sound at work but not home.
さんによる
I hadn't had this problem until today. After checking all the sound settings I swiped down the phone's screen and noticed that Bluetooth was on. Turning that off let me hear the audio on videos on Twitter, thanks.
さんによる
I don't have any sound on my phone at all I have checked for Bluetooth that is off don't know what to do apart from through the phone out of the window
さんによる
3件以上のコメントを表示
コメントを追加
please check if hands free is enable in your device that means headphone jack not responding according to hardware connected or disconnected.
このアンサーは役に立ちましたか?
スコア 7
1件のコメント:
The taking out The battery thing worked. ☺
さんによる
コメントを追加
Take out your battery. Worked for me and several other people have commented that it has worked for them, as well
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
What if you have a built in battery
さんによる
I cant see how i can take out the battery?
さんによる
コメントを追加
You can power off the phone which will correct system errors and power on again and When the samsung logo appears , press the volume down button till the phone opens and safe mode is shown downwards . Safe mode will help you because it turn off third party apps cache data .
このアンサーは役に立ちましたか?
スコア 5
5 件のコメント:
Thanks very much @ghjjhb for your advise, my phone is working normal now. Much appreciated
さんによる
Worked for me as well! Thanks!
さんによる
This worked for me, thank you so much. You've saved me a whole lot of trouble
さんによる
It went silent again, tried everything but it's still not working. Help plz.
さんによる
I already reset my fone but its sound still not working..i cant removed the babttery because its built in
さんによる
コメントを追加
If you have recently updated your phone or flashed a custom ROM, it might be because of that. Try to do a factory reset of your phone, or wipe and reflash to the stock ROM.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Also blew into my headphones jack a couple of times and poof. After a week of struggling updates and everything it just worked again
さんによる
コメントを追加
i have fixed it! for me, it was that my phone thought that a 3.5mm jack was plugged in. the solution is: https://play.google.com/store/apps/detai...
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
I can hear people when they call but they cant hear me and also when I take videos there is absolutely no sound that comes from my phone I dont know what to do please help
さんによる
Same problem how can I do to fix A30s
さんによる
コメントを追加
I was watching a video on my sumsang phone and then all the sudden my phone goes silent and I do not know why . WHAT DO I DOOOO?
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
same here, my speaker just stopped working while i was watching a video. SOMEONE HELP
さんによる
コメントを追加
My Nokia 5 s sound jst disappears…no sound for audio, video,music but I hear whn someone calls me but whn I turn on my speaker th is no sound…whts wrong?
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
how do i get sound to hear phone calls
さんによる
@Missy Presgraves
さんによる
コメントを追加
I was watching videster and my I dropped I had on charge and it suddenly stop working
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
What do I do
さんによる
My tecno C9 suddenly don't work on sound. Please help solve this
さんによる
コメントを追加
My problem was with Google Apps. I noticed a headphone icon on the phone and knew it had not been there long. I knew I had several new Google app icons as well. Once it was removed, the telephone audio returned and the headphone icon is no longer present.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
How did u do it please
さんによる
Hw did you do it pls, my phone is having same issue
さんによる
コメントを追加
my phone doesnt hace any sound
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
My phone was fine yesterday I slept and woke to my phone saying no setwice and there is no sounds. Help mensure! !!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I had this problem yesterday and i had to clear my cache data
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Why do my iPhone don’t have sound
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
one of my friends had the same problem. no sound from his samsung a5 2017, no media, neither ringtone and call. i found he was turned a switch on in accessibility, mute all media sounds. and all the usual sound switches and keys didn’t work any more. i turned it off and it worked correctly.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
my phone thinks theres a headset or speaker paired but there isnt. it happened randomly whilst watching video and the link somebody dropped didnt work for me. someone help?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
My phones video settings default to mute, meaning my received video has no sound
さんによる
コメントを追加
It's the do not disturb button on the phone & that's why the volume won't work,u have 2 turn off the do not disturb button & the media sound will come back on.
CNM.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My phone is a Samsung A70. Not really a solution more of a temporary fix. For me whenever I received a call while earbuds were plugged in my audio would stop working entirely and when adjusting volume the symbol would show that it is adjusting fine and that its not using the phone speaker as the symbol that appears when using a wired earbud was being shown. I never have my bluetooth on so I ruled that out as being the problem. My audio jack port was also fairly clean so I doubt that was the issue. Based on the fact that it gave a problem only when receiving a call made me think it was software related, maybe the phone was getting confused on where the audio should be sent because of the phone call resulting in it not working at all almost as if it is connected to some magically non-existing audio device. After reading some of the comments here I see that we all have the same issue but for different reasons. In the end my solution was simply restarting my phone, it worked perfectly fine after the restart but the following day I was watching a video with earbuds in and someone called me through an app which did not cause and issue however later the same person called using the phone app and it caused the audio not to work again. No clue on the cause but restarting your phone should be your step 1 for a quick temporary fix.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My answer is yes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Check your phone’s volume, ensure it's not muted or on Do Not Disturb. Restart your phone, check audio output settings, and inspect the speaker for debris. Test with headphones as well.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ciera Dixon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 69
今までの合計 831,563
