メインコンテンツにスキップ
Microsoft Corporationによって製造されたXboxワイヤレスコントローラー7MN-0001は、PCでも使用できるXboxゲームコンソールに最もよく使用されるコントローラーです。
Why won't my controller turn on?
Sometimes the Xbox One controller will not turn on, even after replacing or recharging the batteries.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 55
55 件のコメント
My controller had a venom battery pack in it and i put in a charger that didnt work with the battery and now my controller is not turning on. Can anyone help me
さんによる
Same. I had a venom pack it bent it and stopped working
さんによる
Turned my x1 controller on the light dimmed after a moment then just stay off. Put in a fresh set of battery's same issue occurred. I plugged it in via USB stayed in for a moment then turned off. First time this has happened. I've got hardly any interference using only one wireless controller. I'll end up pulling it apart to see if it needs a cleaning or repairs. In the middle of playing mass effect Andromeda really wanna get back into it. Anybody figures out anything keep me posted :)
さんによる
My Xbox One controller still turns in, but I can't tell bc the light on it doesn't work... And it also turns off the second I turn it on and start using it. I can't find any website to help.
さんによる
My Xbox one controller wouldn't turn on since i tried to update it in settings.
さんによる
50件以上のコメントを表示
コメントを追加
12件の回答
ベストアンサー
My controller died during an update and would not turn on no matter what I did.
I fixed this issue by using a known good USB -> Micro USB cable from my phone charger, and fresh batteries in the controller (do NOT assume your cable is okay - try another one if you have it). Turn off the Xbox One and unplug it for a minute or two. In the meantime, plug in the controller using the USB to the side port (probably any port will do, but that's the one I used). Plug the console back in and turn it on using the button on the console, not the controller. After a minute, the light on my non-functioning controller lit up and all was good to go.
Good luck, hope it works for you too!
If you continue having issues turning on your Xbox One Wireless Controller, check out this Xbox One Wireless Controller Won't Turn On Problem Page.
このアンサーは役に立ちましたか?
スコア 64
52 件のコメント:
this happened to me and your info helped. after a few minutes plugged in. it came back on. thanks buddy!
さんによる
Your fix worked - saved me from buying a new controller. Thanks.
さんによる
Might try this on my bricked (repaired connector, it worked for about 48 hours then also died during an update) controller. Wonder if a higher pin number sold with some newer phones will work? I think it might be a timing issue. Will do some more tests with the SDR# and tape antenna on the chip in case I can ID the exact point at which bootup fails. (related hack: do the same to a dead microSD card as its possible to extrapolate data overwritten if expected pattern is partially known though incredibly slow)
さんによる
Thanks for helping get my controller working again!
さんによる
This worked for me! Thanks!
さんによる
47件以上のコメントを表示
コメントを追加
このアンサーは役に立ちましたか?
スコア 17
13 件のコメント:
Dude you saved me a beating thank you so much im so grateful
さんによる
Only thing that worked! You are a hero
さんによる
Thanks for the post did the job for me went through 2 sets of batteries and then tried this method and it worked.
さんによる
Worked!!! thanks brotha
さんによる
You're the man, much appreciated!!
さんによる
8件以上のコメントを表示
コメントを追加
If your controller won't turn on, first try replacing or recharging the batteries. If that still doesn't work, your charge cable may be defective, and may not be charging your batteries. Check out the Xbox One Wireless Controller troubleshooting page for more information at Xbox One Wireless Controller Troubleshooting.
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
Wow it actually fixed my controller now me and my sister could play together now
さんによる
I did a new battery pack wont work tried to connect from controller to xbox wont work and when I use a USB cord wont work it's just trying to connect to the xbox
さんによる
It worked thank you so much I have been trying for an hour.
さんによる
コメントを追加
I bent the battery tabs back outward,, they get pushed in over time causing poor contact. Restoring the spring action of the tabs fixed the issue.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thanks for helping me, I was going to take it to my neighbor who works on electronics, but I read this and tried it, and it worked. I can't thank you enough!
さんによる
コメントを追加
The same thing happened with me but I looke at my Xbox and saw it wasn't on unplugged everything plugged it back in Xbox turned on and the controllers started working
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I tried 4 times and it doesn't work wtf
さんによる
Same here, I tried everything he did and still nothing.
さんによる
Do you even know proper english? Do that first before telling us something everyone already knows or tried...
さんによる
コメントを追加
I have had no problems with my xbox had it since the kinect first came out since then i played with power packs on my controller and the for some reason it stopped connecting after that a bought a wired controller used that then soon didn't wanna work either then i said ah what the hey i bought a another wireless controller worked for a bit then battery pack stopped working so switched to rechargeable batteries now controller does not turn on what so ever no power no sync nothing i tried with a power cord nothing fresh batteries nothing. Tried power cycling the xbox and nothing i am at a loss now way to controll my xbox i am losing my mind and keep in mind i have only had this $64.00 controller for 3 months
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
This happened to me. Xbox one controller dead, even with new batteries, I thought it was goosed, what I did was took the batteries out, plugged it in to the xbox and kept pressing the middle x button that normally lights up when connected, nothing happened at first, then after about 30 seconds of repeated pressing the x miraculously lit up, I disconnected it from the cable, replaced the batteries & it now works as normal, hope this helps someone.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
\\\\absolutley horseshit
さんによる
|dont freaking swear
さんによる
コメントを追加
Try putting the plus poles on the plus side and minus on the minus poles.
This can solve your problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It could be a physical problem, water stuck in the controller or otherwise.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
So I just fixed this problem incase anyone runs into it in the future. Just unplug your Xbox for 5 mins and try again. Hope it works for you to
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
So i was playing on my friends Xbox with him and all the sudden (i was playing minecraft in the end with him) the controllers stopped working how i fixed this was i took the batterys out and i pluged my controller into the xbox and it worked (if u unlpug it it stops working)
I hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Another solution to try.
if the controller doesn’t turn on or stays on. Reset Xbox by pushing and holding the power button until it shuts off. Wait 10 seconds or more.
Connect the Xbox controller to a USB cord (connected to Xbox) ,turn on the Xbox by pushing the power button. When the Xbox is on try to turn on the controller if it turns on great however if it does not simply push the sync buttons on both the system and controller sometimes by holding both the power button on the controller while still trying to sync it. You may have to try multiple times while doing it.
Once it’s done go to your settings, devices and connections, accessories. Once there click the three dots to update the controller as it may need updates. One of the reasons why your controller couldn’t connect to the system
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Garrett George さん、ありがとうございました!
統計データ:
過去 24時間: 29
過去 7 日: 178
過去 30 日: 869
今までの合計 403,488
