メインコンテンツにスキップ
キッチンツールの解体と修理ガイド
3525回答 すべてを表示
Kitchen scale power button works intermittently. Fix or replace?
Hi. I have a Salter kitchen scale (Model 1008USSSBKDR) and I have to press the "on/power" button numerous times before it powers up. Seems to work fine once it does finally turn on, but I can push it (literally) 200 times before it works. most times I just give up.
I really like the scale, and it wasn't cheap. I'm wondering if I can somehow fix it. Not very electronically savvy, but I am mechanically minded and I'm game for a challenge. Thank you in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
I had two similar salter scales (model 1051) which were very difficult to turn on/off after some use. Changing batteries and licking fingers didn't work. The fix is easy, just clean the switch(es) with a solvent to remove the almost invisible coating (patina) that builds up from the grease on your fingers. Both my scales are now working like new. I used a tiny bit of 100% alcohol on a q-tip (cotton bud) and rubbed the touch-switches for less than a minute. I'm sure lots of other solvents will also work.
I discovered this when taking the scales apart to fix ithem and noticed that touching the inside surfaces of the touch-switch (where there was no grease layer) successfully turned the scales on.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Also worth mentioning that these scales need batteries near 1.5v. So NiMH rechargeables must be fully charged to about 1.4v ( nominal value is 1.2v). These rechargeable batteries also loose charge over a few months.
さんによる
I found taking the back off and cleaning out the cobwebs (yes, amazing how they get there) made turning on much easier. I have read that cobwebs are conductive if relative humidity is about 40% (60-70% in out house).
さんによる
コメントを追加
回答を追加する
danielmillen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 18
過去 30 日: 49
今までの合計 5,421
