Broken 2013 logic board, upgrade to 2014?
My logic board on my MacBook Air 13" mid 2013 is damaged from coca cola spill :/
Can I change the 2013 logic board to 2014?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Here's a listing of systems within this series: MacBookAir6,2.
As you can see there is a few Early '14 that you could swap out the logic board with. These logic boards are not cheap! You may end up being happier just buying a new system.
You still could have issues within the keyboard and trackpad from the spill. So think this through carefully.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 283
8 件のコメント
Please give us the last four figures of your serial number (located on the back in very fine print), so we know your exact machine.
mayer さんによる
Or maybe I can downgrade to 2012? Cheaper...
Mike さんによる
Will mid2013 1,4ghz fit into this? I have mid2013 1,3ghz.
Mike さんによる
Cleaned all parts.
Well, now it starts... but stops again... will do the cleaning again.
https://www.youtube.com/watch?v=_hSYSUqT...
Mike さんによる
I can't speak for this specific Air. Some of the older ones had issues with using a different revision of the same LCD with the motherboard.
ABCellars さんによる
3件以上のコメントを表示
