メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
16、32、または64 GBのストレージ容量を持つ、第3世代Apple iPad Wi-Fiモデルの修理ガイド、分解手順、およびトラブルシューティング情報です。2012年3月発売。モデル番号A1426で識別されます。修理には加熱と慎重なこじ開け作業が必要です。
not charging when plugged into wall, but charges from computer
My iPad won't charge when plugged into the wall charger. However, it will "trickle" charge when plugged into the computer. I tested both the charger and the cable with another iPad and the second iPad charges just fine using that wall charger and cable. Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
This happened to me and I found a SOLUTION!!! On a whim, i tried to used my sisters “ultra fast charger” for her Galaxy note 10 and it worked!!! It’s the only charger that works. I ordered one off of amazon(not a samsung branded charger) and thankfully its been working great.
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
Has your iPad been repaired/manipulated from the inside before? Dropped? Water damaged? Have you been using a cheap charger? Answer those to help figure out the issue.
Otherwise, here's a troubleshooting guide for the most common issues:
1- The charging dock could be A/dirty or corroded, B/unseated due to a drop, C/Damaged:
1-A/ Gently clean the charging dock (where the charging cable connects) with a tooth-brush dipped in 90%+ isopropyl alcohol while iPad is off.
1-B/ Be warned that you could easily break the glass for this one: use this guide to open the iPad. Look at the battery. Is it swollen? If not, unseat the connector, clean it with IPO and a toothbrush if you like, then re-seat it and test. If battery is swollen, it could be that the battery is acting out. You will need to replace it.
1-C/ Try a new charging dock.
2- The data and/or power management circuit on the logic board could be acting out due to a number of causes such as those mentioned at the beginning. I had a similar case where that circuit was damaged and the iPad would charge from the laptop but not the wall charger.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
Thank you for the great suggestions... I cleaned the dock connector with 90%+ isopropyl alcohol and it solved my problem.
Thanks again for your help.
さんによる 共有
Please accept the answer then to close this case. Glad it worked!
さんによる 共有
My i paid water damage now battery finish i open and wash and heat but now when i contact charger it's processor heated please solution
さんによる 共有
コメントを追加
回答を追加する
vakeit さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 59
今までの合計 14,462
