メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2396回答 すべてを表示
Is there any chance to check faulty cables?
Hello everybody,
I try to repair my old iPhone 4. It only show me the the iTunes logo. When I try to reset it with iTunes, I got error code 4013. I tried 3 PCs (Mac and Windows) all where clean and without antivirus software but always the same error.
So I decided to open the phone but all connections looks good. I replaced the battery and the connector port.
Is there any chance to check the connectors or cables to find the error?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
I'd try all the steps in this list before attempting hardware repair.
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
Hi Rany, thanks but there is no information, how to check for faulty cables. In the comments, I found an interessting hint to disassemble the front camera connector.
さんによる
Nope, to rule out defective cables, unplug them all, plug in the battery, the charging dock, and start the phone (by hooking it to a charger).
See if you can restore with this minimal set-up.
If not, try a different charging dock, or better yet (if possible), transfer the logic board to a known good phone, hook everything, and try to restore.
In my modest opinion, the 2 cables that may cause an issue for the iPhone 4 would have to be the charging dock, and may be the power button cable.
Next step would be to check the logic board for missing/damaged/part-removed or corroded components, especially around the connectors on top (cameras, screen, power, etc.), middle (charging dock), and bottom (battery).
さんによる
Hey Rany, is it really possible to start the iPhone only with the battery and docking port? I mean without the screen, antenna and the other parts? I thought all components must work to use or restore the device.
If this methode really works, that would be awsome and possible to find faulty parts. :)
さんによる
Sorry, you need the screen too. Yes, you can try a restore with only the dock, screen, board, and battery. Press & hold Home Button, and while doing so plug your phone into your computer, it should start in recovery mode. Release Home Button and start the recovery process. My money though is on hardware issues on the logic board, but trying this restore is not gonna cost you anything, so why not. And to make the trouble shoot complete, you ought to try a different known good charging dock if the phone fails to recover with the one you are currently using. You could also try to clean the prongs of the charging dock (where the sync cable is inserted) with a soft toothbrush dipped in 90%+ isopropyl (rubbing) alcohol.
さんによる
Thank you again Rany. I'll try it out in the next days and will report. The charging dock is brand new like the battery. I really hope its only the front cam, Antenna or so.
さんによる
1以上のコメントを表示
コメントを追加
Hello,
Have you tried with another charging USB cable?
Error code 4013 means there's a hardware problem.
When did it start doing this?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hey, yes I tried out 3 diffrent original Apple cables.
One night I went to sleep and in the morning, the phone was dead. I tried to start it but nothing. After some minutes on the recharger, I got the iTunes logo.
さんによる
コメントを追加
Are you using the usb ports at the rear of the computer, as the front ones can have a tendency to not play ball. I've had an ipod 4th gen and an iphone 4 not work on the front, but works on the rear.
Else, try using google for changing itunes host file, as this has worked once for me too.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hey Duane, I used both USB sides and the host file is clean. FW are antivirus are disabled.
さんによる
コメントを追加
回答を追加する
Iceberg さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 6
今までの合計 138
