メインコンテンツにスキップ
Remove broken screw from retaining bracket
Inside my MacBook Pro 15" (Early 2008, model A1260) there are 2 screws that hold down the hard drive retaining bracket. One of the screw heads broke off, leaving the entire screw in the bracket with nothing to cling onto. I am now unable to remove the screw, which in turn won't allow me access to remove the hard drive. Is there a way to remove the broken screw?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
Is the head completely gone or is the torx "round" ?
whe the head is completely gone, it would be the easiest thing to remove the drive - without the head - it can hold nothing
but when the head is still there, but round - use a screwdriver that almost not fits on the screw (a little bit larger than the round hole) - press it in the screw and screw carefully - that way i always get the dead torxes out (ok, to be honest - i do something more often than others and in hardes cases - i use my dremel ;-) )
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The screw head completely broke off. The screw stem is screwed into the retaining bracket holding it securely in place.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Archie Korbiel さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 2,381
