メインコンテンツにスキップ
モデル番号A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5もしくは3.5 GHz Core i7 Processor, ID iMac14,2
27" iMac can I upgrade to a fusion drive later
Its the low end iMac 27" brand new machine
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
2件の回答
ベストアンサー
Apple does not offer upgrades for their systems.
Apple currently does not offer its custom SSD units so if you bought a HD model you likely not be able to update the SSD later.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
If you haven't actually bought the computer yet, just swallow hard and pay the extra money for the Fusion Drive. Even if the WD Black2 I describe does work, the PCIe bus used by the Fusion NAND cache is faster than the 6GB SATA cache used by the hybrid drive. Apple is turning computers into appliances, where what you get when you buy it is all it can ever be. In those situations, you're always better getting more of the non-upgradeable goodies, in this order: More RAM, more/faster storage, faster video. If you're a gamer or a graphics pro, you might move graphics above storage, since you can run external drives.
さんによる
Agreed! If you haven't bought a system dig a bit deeper to get the Fusion setup if that is what you want here.
さんによる
コメントを追加
最も参考になった回答
Officially, no; the drive you get when Apple builds the computer is the drive you're stuck with.
The Fusion Drive consists of two physical devices: A traditional spinny metal platter hard drive, and a solid-state NAND cache, similar to an SSD. CoreStorage allows you to format the two physical devices as a single logical volume using Disk Utility; the resulting volume is the Fusion Drive, which stores the most frequently accessed data on the SSD (such as the operating system and applications), and stores the less-used data on the platter drive. In the Mac mini, the two separate drives used to mount in stacked SATA bays, similar to the stacked hard drive cages in towers.
Apple has a connector for the PCIe solid-state drive module on the logic board, which in Fusion builds is used for the NAND cache that's mooshed together with the traditional SATA hard drive to create the Fusion Drive logical volume. But there's a good chance that the SSDs Apple uses have special firmware; that's what they did with the 2013/2014 Macbook Pro/Air laptops, which use similar PCIe modules. If you stick a generic third-party module into the socket, you may not be able to communicate with it.
Unofficially, it's hard to say. I haven't read any reports of someone trying to install such a PCIe module and failing, so who knows? Maybe Apple uses a different implementation on the iMacs. If you're inclined to try an experiment, iFixit has a guide for removing the SSD in a 2013 27" iMac; I'm guessing that the logic board of the 2014 non-Retina generation is similar. From the looks of the socket, the module uses an mSATA connector. But you'll only know whether it works once you've reassembled it.
There is another alternative. About a year ago, Western Digital released a 2.5" hybrid drive with 120GB NAND cache + 1TB platter drive in a single 2.5" laptop drive mechanism, under the name Western Digital Black2. Until recently, this drive was not supported under OSX. A tip from DealNews about NewEgg selling this drive for $120 drove me to Western Digital's website, where I discovered that not only is the Black2 now supported under OSX 10.9/Mavericks, but Mac-based firmware patches and configuration utilities have been released. Configuration options include Dual Drive (treating the 120GB SSD and the 1TB HD as separate devices) and Fusion Drive.
Yay!
The WDC documentation specifies 10.9/Mavericks support, but that document was written in August 2014, two months before 10.10/Yosemite was released. I suspect that, if the drive actually works under Mavericks, it will work under Yosemite the same way.
So, instead of messing around with possibly incompatible SSD modules, you might try replacing your existing hard drive with a Black2, and get most of the Fusion functionality that way. You'll also need to get a mounting bracket to install the 2.5" Black2 SATA drive into the existing 3.5" drive bay. It will be exciting to see if this works; I'm planning to try it in a laptop just to see.
Excelsior!
2015.05.10 EDIT: I have just discovered that WDC has updated the install notes and OS X utilities for the Black2 SSHD; formatting as either separate SSD/HD volumes or as a conjoined Fusion Drive is now supported for OS X 10.10/Yosemite.
iMac Intel 27" EMC 2639の画像
ガイド
iMac Intel 27" EMC 2639 Teardown
難易度:
中レベル
iMac Intel 27" EMC 2639 ブレードSSDの画像
ガイド
iMac Intel 27インチ EMC 2639 ブレードSSDの交換
難易度:
難しい
1 - 3 hours
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
So you remove the internal drives and replace them with this Black2 and all will be good?
さんによる
Well... Not really. Its still best to buy the iMac with the SSD, then upgrade the system by adding the HD later. If you have already bought your system without a SSD then going with a 3.5" SSHD would be best (the WD Black2 drive is a 2.5" drive). While the Black2 drive does offer a dual drive setup within the single device the SSD & HD can be seen discreetly as two drives (unlike the Seagate SSHD which you see as a single drive). The M.2 Blade SSD Apple offers much better performance combined with a straight HD than either and the 3.5" Seagate SSHD is better than the WD Black2. Don't get me wrong here the WD Black2 is a good option for a laptop system.
さんによる
According to WDC's manual, their formatting tool will permit you to configure the two modules (SSD + HD) in the Black2 as an Apple-style Fusion Drive. That said, in the year since my original answer was posted, the Black2 got some bad feedback for configuration issues. The drive has now been discontinued, retail prices have doubled from last year, and falling SSD prices have made the Black2 a less appetizing option.
さんによる
コメントを追加
回答を追加する
Scott さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 14
今までの合計 16,944
