メインコンテンツにスキップ
Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
745回答 すべてを表示
締切られた回答
Wifi Problems with Same Parts, but Different Shell
Here is an interesting problem that is really baffling me.
I use the same parts for the components for the wifi/webcam that is on a MacBook Pro (Wires and all), but when I place them in a different display shell it doesn't work, but when placed back in the original shell it does.
Swapped shells because the old one was damaged and had one in decent shape laying around.
Any suggestions?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Might be a silly question but did you verify the new shell had the correct drivers? are you only replacing the shell and nothing else? such as motherboard, HDD ect.
さんによる
Like I said, all I swapped out was the top half and I took all the wires, cards, and LCD Screen and placed them in the new shell.
So all the parts should be fine. That's where I'm confused.
さんによる
The guys are the same, just moved. The shell was from another MacBook of the same size, but since the guts were a 2011 MacBook parts, I took those out and put the 2009 guts in. His includes the iSight board, airport, blue tooth, all that and the wires. So logically this shouldn't be happening.
さんによる
コメントを追加
1 件の回答
ベストアンサー
If the boxes are different years you may have a problem with the card not being supported.
When you check the System Information-Network:WiFI does it recognize a card as being mounted? And of course you remembered to remove the old WiFi network service from System Preferences-Network, and create a new one for the new setup?
If this answer is acceptable please remember to return and mark it accepted.
このアンサーは役に立ちましたか?
スコア 1
12 件のコメント:
Sorry took so long, had to get the video working first, and now that that works I checked the Preferences and it has Wifi greyed out.
さんによる
Check System Information - that is where the computer detects hardware at boot. If it's not detected then of course you can not create a service in network. The reason it might not be detected could be a bad slot or card. (Not too long ago someone here had a problem of an undetected card and it turned out one of the connector pins was bent. He was able to realign it without breaking it off and all went well).
さんによる
Wifi: Software Versions:
CoreWLAN: 5.0 (500.35.2)
CoreWLANKit: 4.0 (400.35)
Menu Extra: 10.0 (1000.33.2)
System Information: 9.0 (900.9)
IO80211 Family: 7.0 (700.52)
Diagnostics: 4.0 (400.68)
AirPort Utility: 6.3.4 (634.17)
This is what it says for the 'Wifi' section. When I had this in the other top shell it said this and the network data.
I ordered a new Wifi Antenna, just incase, since I found them off a supplier site for $1, $5 after taxes and all that though.
さんによる
Under System Preferences->Network: on the left column did you hit the + at the bottom and create a new service for Wi-Fi and then enable it?
さんによる
I did and Wifi doesn't show up. Just Bluetooth (PAN and DUN, Ethernet, and FireWire.
さんによる
7件以上のコメントを表示
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 176
