メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
No sound, not through speaker, mic or headphone
My iPhone 3GS does not have any sound at all. The earpiece, speaker, and microphone do not work, also sound through the headphones does not work. I thought it was stuck in headphone mode, but that's not the case. When i press volume with the headphones in, it says "headphone volume" and when I plugh them out then it says normal volume again.
In short, there is no sound in any possible way. No waterdamage, and the dockconnector has already been replaced.
Is there like a sound chip on the logic board that might be broken, and can I fix this? Or do you guys think it's something else?
Any help would be greatly appreciated!
Thanks,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
did you try to restore it ?
even if i don't think that it would change anything.
many iPhone 3G users had this problem and the phone were all replaced by apple.
maybe you should try that too (as long as you don't have any opening marks on the phone)
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
+ Ralph
さんによる
Yeah, it's been restored a couple of times. I know it's not a software issue, it's hardware related. And thanks for the suggestion of returning it, but if I could have done that, I would not be asking here ;)
But thanks for your reply :)
さんによる
コメントを追加
take a pair of headphones and insert in the jack pull it out put it back in raptly when the phone is on the hold the power button and home button at the same time and it will power off quick and reboot sound should come back on if not repeat the steps ...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mike さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 11,783
