メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
締切られた回答
Home button/ lightning connector
My home button ribbon recently broke. I haven't replaced it yet because my phone won't stay connected to iTunes. I figured I would get that taken care of first because I know how to use the assistive touch function. I recently put in a new battery and a new lightning cable thinking it would fix the problem. But Ive had no luck. Then I had a thought. I noticed that the home button is connected to the Lightning cable. My question is, is it possible that my phone won't stay connected to iTunes or charge properly because there is absolutely no home button connection? I'm getting frustrated because when I connect to iTunes, it goes through the whole process of trying to update, then about 20 minutes in it says it lost connection. Please help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Use another charger cable incase that one is faulty
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It's not the cable. My wife uses that cable every night.
さんによる
コメントを追加
I use to have issues with my phone, it turns oput that the plug for the charger was in fact dirty and had built up dust and stopped it from charging.
If you have the little metal stick it came with (for opening the sim card) use that and get the dirt/dust out of it then try and charge. Hopefully it should work.
If this has helped please accept the answer.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It's not the cable. I've tries 4 different original Apple cables all with the same outcome.
さんによる
コメントを追加
I can tell you the home button not being connected isn't the problem. I never connect the home button whilst testing the LCD and it is always fine. What do you mean by it wont stay connected? does the phone still function okay despite this?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Since the battery went dead, I haven't been able to use it
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 171
