メインコンテンツにスキップ
The iBook G3 was unveiled in July 1999 as Apple's portable computer for consumers.
Why does my screen flicker?
When I turn on my G3 it has a beautiful picture. After about 10 minutes, the screen flickers with horizontal and vertical lines of all colors. I cleaned the fan and added heat sink compound. The problem still exists. What else can be the problem and can I repair it (self-help)? No computer operates fine other than that problem with the video.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Sounds symptomatic of the G3 video chip flaw. Clamp to the left of the trackpad and apply pressure, and if that affects what's going on on the screen, this is the problem. Please see my post on a previous question:
Why does my iBook randomly freeze?
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
Have you tried connecting the laptop to an external monitor? If the same problem happens on the external monitor, then you have a bad video card on the logic board. If the external monitor works fine, then you may have a problem with the LCD or Display Data Cable.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Cornelius Morgan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 2,372
