メインコンテンツにスキップ
Samsungの第五世代Android携帯のGalaxyスマートフォンは2014年4月11日に発売されました。指紋認識、より高度化したカメラ、より拡大したディスプレイ、防水性などを含む改良されたセルラーフォンです。4つのカラーから選べます:黒、ブルー、白、コッパー
577回答 すべてを表示
締切られた回答
Samsung Galaxy S5 has battery or charging problem
Hello,
I have a problem with my Samsung Galaxy S5 .
The battery runs out very quickly , I bought a new battery, and I still have the same problem. My phone is discharged after 4 or 5 hours , even if I do not use it. Suddenly I realized that the problem is related to the device, and not to the battery; but I have no idea how to fix it.
Thank you in advance for your answers :)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
1.The first thing to do is make sure that you are using the Samsung charger and cable that came with the S5. Other chargers may have different voltage ratings and they won’t always work with the S5. Give the phone a good 30 minutes plugged in before you try to turn it on.
2.Try changing the wall socket and using the cable and charger on a different device to make sure there are no faults there. Try a different charger and cable with the same rating.
3.Try plugging the S5 into a USB port on your PC or laptop. Bear in mind that it will charge more slowly from a USB port than from the charger plugged into the wall.
4.Take a look at the charging port, blow into it or use compressed air to make sure there’s nothing blocking it.
5.If it still isn’t working then you may have a dead battery or a broken charging port. replace the charging port yourself. Here’s an iFixit guide, but it’s a complex procedure.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,634
