メインコンテンツにスキップ
iPhoneを自分で修理するために必要なものはすべて揃っています!最新のiPhone 15から、2007年に発売された初代iPhone 2Gまで、iFixitにはすべてのiPhoneに対応する無料の修理ガイドと分解情報があります。
36478回答 すべてを表示
Removing OCA bubbles on LCD using autoclave/laminator
Hey all,
Just wondering if anybody with an autoclave/vacuum laminator can tell me how they find it with the results and if they use a press to apply the OCA or just their hands and a roller? I've seen a few advertised but the seller is claiming the autoclave will not remove all bubbles if it's not done with a dedicated vacuum machine.
Any advice is appreciated, thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
David James, I believe that an autoclave is a pressure chamber to sterilize equipment with high pressure steam. Not sure how that will help with a LCD repair. I thought that you would need a vacuum laminator to do a good OCA repair, not an autoclave.
さんによる
it removes the bubbles when the glass has been applied to the lcd/oca. here's an example: http://www.aliexpress.com/store/product/...
a vacuum laminator is better but they are around $2000
さんによる
Sorry, the title is misleading, i've only just noticed.
さんによる
コメントを追加
3件の回答
最も参考になった回答
Hello, usually the autoclavecan remove vacuum bubbles, but can not remove air bubbles, so you should take care when put the oca on glass or on lcd.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
What can I do to eliminate air bubbles?
さんによる
You can use Autoclave LCD Bubble Remove Machine, it is uaually used for refurbishing LCD screen.
さんによる
How many times can you put it in the autoclave because have bubble When I take the lcd out of the autoclave the bubbles will be 100% gone, then slowly come back
What advice can you give me?
さんによる
コメントを追加
Hi brother,
if you want to remove the OCA bubbles , you need use the autoslave.
the autoslave setting reference: time: 15 minutues press: 0.4-0.5mpa temperature: 30
we advice you use the mitsubishi OCA, is easy remove OCA bubbles.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
A good OCA and a good aplication of oca is 80% of work 10% laminating and other 10% autoclave in my opinion
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David F さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 11
今までの合計 5,626
